'96 Sea Doo slow to rev up then runs good
mobjack75
I recently purchased a '96 Sea Doo GTI Bombardier that had been setting for several months. It starts and will rev up out of the water. In the water, you really have to work with the throttle to get it going. Once going it runs good at high speed. I was wondering if the low speed jets need to be adjusted. I talked with a repair shop and they say there isn't any adjustment. He says the problem is the diaphramm in the carbs. Has anyone had this problem, and what was the solution?
Welcome to the seaadoo forum mobjack75. The carb settings on your seadoo are as follows; the Low Speed screw( has a pin through it) should be set at 1 1/4 turns and the High Speed screw ( has a plastic cap on it)should be set at "0".
It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. If you have gray fuel lines you need to replace them with black fuel lines available from auto parts stores like Auto Zone. Measure the length you need and bring a sample with you so you get the correct size. Replace one at a time so you don’t get them mixed up. If you need clamps replace them too. Use small stainless steel clamps also from the auto parts store. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
The seadoo forum also has a seadoo parts warehouse to buy from. Click on the"Parts" link at the top of the page.
Karl
How do I get to the low speed adjustment screws. What do I have to remove to get to them. I have the repair manual that shows a picture of them but I can't get to them. Luther
once you remove the giant black air box on top of carb and it's base plate you will have access to whole carb-side of the motor. go get a set of metric allen-head sockets. life is so much easier than trying to spin full length allen wrenches in the engine ciompartment. only about 15 bucks at autozone. comes 3 thru 8 or so mm. you will use 4, 5 and 6 a lot. while you are at the parts store, get some PB Blaster. best freeing oil in the world. soak the adjust screws before you touch them.
I have removed the plate and I see two adjusting screws. They both have a tab on the bottom side which would not allow a full turn. Are these the low speed or the high speed screws?
Welcome to the seaadoo forum mobjack75. The carb settings on your seadoo are as follows; the Low Speed screw( has a pin through it) should be set at 1 1/4 turns and the High Speed screw ( has a plastic cap on it)should be set at "0". It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. If you have gray fuel lines you need to replace them with black fuel lines available from auto parts stores like Auto Zone. Measure the length you need and bring a sample with you so you get the correct size. Replace one at a time so you don’t get them mixed up. If you need clamps replace them too. Use small stainless steel clamps also from the auto parts store. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
Did you read this post?
