Hello everyone,
I purchused my first sea-doo put it in the water and somthing doesn't seem right. I'll try to be quick with my problem.. Put it in the water and it struggles to get out on acceleration, engine runs good lots of rpm 6000-7000 all the time revs hard no laging. Once i'm above the water it goes good but I have to keep it wide open to keep any momentom. After some research I attributed it to be the wear ring or impeller. I am mechanically inclined so i removed impeller housing as per instruction manual but the wear ring doesn't look bad, no nicks or chunks missing, clearance .015 and impeller has a couple dings and edges are beveled alittle but nothing that I would call serious, back lash is .040?? The only other thing is when i pulled the cone off for the oil pump there was only alittle oil that drained out maybe 3-4 tablespoons i'm wondering if that isn't my problem doesn't that have somthing to do with the impeller or am i incorrect. Any help would be great before i start throwing parts at it, thanks for your time..
