mejim707
Yes, you can just pull the plugs and pour just a bit into each cylinder. It’s really not necessary, as there is plenty of oil trapped in the crankcase to get you through the initial startup. The pump flows almost no oil at idle anyway, so you’re not going to hurt anything, but you can add a little oil or premix if it makes you feel a bit better.
These motors are high strung for sure, but they’re far more resilient than people give them credit for. Just use the correct OEM parts and a good synthetic API-TC rated oil and let her rip...
Hi Jeremy, so I tried the suggestion on filling the oil lines. I started it up then pulled the lever on the oil pump. This caused the engine to rev because the cable is also connected to the throttle it seems. I watched the lines but after only 10 or so seconds it maybe filled about 1.5 inches. I'm slightly concerned about running the engine for longer and causing damage.
How long is it safe to run the engine for without the oil getting into the mix? Also, should I remove the cable connecting to the oil pump before moving the lever?
Thanks
