Bflauto
Im changing out the oil lines and cleaning out oil on my new to me 96 GTX. The previous owner put the wrong kind of oil in it (some blue crap, said it was pennzoil 2cycle).
So i took the oil pump off the stator cover to make it easier to replace the lines and add hose clamps.
When i put the oil pump back on, should i replace the o-ring (part #24)?
What is the preferred way to prime the oil injection lines? Do folks use the drill-in-reverse method?
Or can i remove the spark plugs and just crank the starter for 30 seconds until the injection lines fill up?
If using the starter method, should i dump some oil in the pistons to help lube while waiting for oil lines to fill up?
Thanks
Thanks
