96 GTX No water coming from pee hole, Rookie needs advice
Fields
Unit runs good on hose squirts water out the rear. However was not shooting out water through the rear unit at the river. Noticed it also ran great at first in the river however would only run half speed.Almost like it was surging.
Changed the plugs , good fire ,compression , The only thing I have done since last year is the water flow regulator valve appeared to be leaking slightly last year so I pulled it out to clean off or just to look at it as I recall.
Could the surging be related to the Water flow regulator valve? It shoots out of the hole and then didnt get up to full speed. Weird when first left ramp all was good except the water squirting.
Any advice,,
