Hi all. Thanks to info posted on this forum and others, I was successful in rebuilding the fuel system on a 96 GTX I just acquired. Great sticky post on the carb rebuild. Wow. So helpful.
Anyway, moving on to other components that don't work. Hoping to get a list of things I can check on each.
First, speedometer.
The paddle wheel is there, and spins freely. I've read maybe the sensor is bad...maybe the sensor is corroded inside? Is there a fuse in that brain box for the speedo? Has anyone experienced the gauge itself failing? Any help on what to check for here would be great.
Same with the multi function gauge. It's just blank. It looks like the before pic in this rebuild kit...
https://www.ebay.com/itm/DIY-Older-style-SeaDoo-Multi-function-Gauge-Repair/223195028654
The float in the fuel baffle is there and moving...but I don't know if the magnet is there. Regardless, the rest of the Multi function gauge doesn't work either. I don't know if the circuit board in the fuel baffle is working...apparently there is a fuse in there that blows? Does this gauge have a fuse in the brain box?
What else should I be checking to get the multi function gauge to work? Any suggestions would be appreciated.
Thanks!
First, speedometer.
Thanks!
