fuses, wiring connections at the Rectifier and MPEM. Battery cables, and Neg battery cable on the engine.
feel for stiff wires, oxidation migrates up under the insulation sometimes you get a High resistance connections, where a higher amperage load will pass through, like turning the starter motor, but lower amperage, like charging won't. all wires should be soft & flexible, ho festering up at the ends, and fuses with clear silicone grease packed in the fuse holder can insulate the fuse. silicone grease AKA plumber's grease, DiElectric compound, is great stuff, but make the electrical connection first, and then apply it to waterproof the connection, like battery cables, fuses. The Seadoo wire connectors are built to be waterproof, no need for it there.
