96 GTi, typical bogging at full throttle, 10 seconds run strong, 3 seconds bog, repeat. Pulled tank, fuel valve, fuel filter. Cleaned everything, installed new fuel lines, pulled and cleaned carb filters (pretty well plugged, especially PTO). Carbs looked very clean inside otherwise. Runs much better but still has random bogging 1/2 throttle and above. Is crud in jet or valve seat most likely the next place? Or is full carb rebuilds the only answer?
Any body in north central Indiana that can help on going through the carbs if I pull them?
