snozeberriestastelike
Hi everybody new guy here. I recently picked up a 96 gti. Did everything imaginable to get this thing running. New top end ,new crank, clean carbs replaced seals, gaskets, plugs,etc. Now that I have it running I'm fixing the small details. Right now I curious about the gauges specifically the fuel/info gauge. Other than corrosion what/why do these gauges not work? The original gauge was shot. Bought a decent looking used one that also didn't work. So as a tinkerer I cut it apart. The boards look good with minimal amount of corrosion that I hit with some electrical cleaner a brush. I check power were I could. But yet it doesn't work. Well I bought a second even better looking used one and it too doesn't work. The skis wiring all checks out as well. I would like to figure this out without buying a ton of non working gauges if possible.
