i am at my witts end with this, it will run on trailer but boggs and cuts out about 3000 rpms max and it cutts out. i have checked and changed and cleaned alot of things with the same end results.
changed rectifier
checked stator all good
rebuilt carbs
new fuel lines
bypassed on off fuel selector
clipped plug wires 1/4 in
new battery
many plug changes
new fuel filter
checked and cleaned baffle
new fuel
compression is 145 each cyl
my last water test was yesterday and it still wont run right on the water. i keep on getting oil fouled plugs so can i try a hotter plug than the br8es? or do i need to adjust the carb settings. tonight i was giong to re adjust the throttle cable and oil pump cable and try to set the lsa and check to see that the hsa is fully in.
the motor was running perfect in my 96 gsx and i took it out to get this boat up and going for the rest of the season.the carbs are off the gsx and the plugs would get a little oily but i figured a little rich is better than lean. i had no problems with it all season since i rebuilt it and got it going so i dont understand why im having this happen now.
changed rectifier
rebuilt carbs
new fuel lines
new battery
many plug changes
new fuel filter
new fuel
