Bro that hood is to die for. So freaking jealous. Dying with envy LOL. I’ve been researching it and no where to be found.
You are one lucky SOB [emoji12]
No twin pipes are a hassle. They are for running fast and are no good for cruising.
I'm not familiar with the Skunk2. Here are some specific to skis, probably the same thing.... PWC Aluminum Washer Anodized for Transom Stringer Mounting. 8mm. IJSBA | eBay
Yes I use Candoo GPS. It's a great product and easy to install. I have almost every kind of finger throttle ever made so feel free to hit me up. I have that carbon fiber rear hatch also.
You better ride that off-brand Yamiturd manufacture's mistake before you put any time and money into it. B1's are the pride and joy of many a serious ski guy out there but not the B2. They are not legal for sport racing so that may part of the problem. A specific job of "surf ski" might be something it can do but I just can't get over it's lack of Seadooness lol.
I had a WB2 a couple years back that was mint and ..... it sucked. It was slow and underpowered. Tops out at 45 mph. They totally suck and are not even fun to turn on like a WB1. I got it and my 96' XP with a trailer all for $500 and even then I couldn't justify keeping the WB2. It really was that bad. Mine was the 1997 with the adjustable trim. I am sure they are dead reliable but just not a good ski even in the surf they are no bueno.
She catches my eye every trip to the shop. I'm just not sure I'm ready for a project of this magnitude right now.
I don't run any stock steering components but a full billet UMI system. Those have stainless "L" brackets that go under the mounting hardware on either side of the stem to hold the DESS post and the choke cable.
Yes those hood posts are fully adjustable. Grab a 13mm, a 17mm and maybe a 19mm(3/4") wrench and set them where you want them. It's good to have to come down on the hood with some force to get it to click so don't set them up too high.
If it's the spot that is drawing air in then you should see water dripping from it. You can keep the back pinned to the trailer and back it into the water a little bit while you watch. If a ramp is not close you could use the hose but slide the ski back on the trailer and tilt it back so the water is not coming up over your VTS module.
