Alrighty folks, I got her fully assembled. I primed the air out of the oil lines. At first I was concerned at the flow rate I observed, after doing some deep web research and a quick ref to the manual, I am happy with it. HOWEVER....
After I double, triple, quadruple checked everything (that I know) I finally made the decision to put the plugs in and cross my fingers.
SHE FIRED RIGHT UP!!!!
FOLLOWED BY AN IMMEDIATE RUNAWAY..OMMFG MY HEART DAMN NEAR JUMPED OUT MY CHEST.
Luckily, I've had this happen to me before on a gsx-l I used to own , and learned the hard way on how to resolve. Pulled WOT and killed it.
Now....what in the Sam h-e-l-l. double checked adjusters, idle, looked for any red flags, gasket seals etc. I've found nothing.
Tried it again, fired up, 4 seconds layers, runaway. turned LS to 1 1/4, 1 1/2, 1 3/4 , 2. runaway runaway runaway runaway!!!
Lol have to upload the comical video somehow, maybe a YouTube link, is it possible to embed?
Anyway, the thing is starting right up and does a moderate climb to about 3k, then Falcon9 rockets thru the rpm band. :/ With my older ski it would hang out for a bit then shoot up, then blow up. lol
I did adjust throttle cable today, and I've read that there should be "some" slack, but how much is some? My current adjustment is spot on (I think
). not tight, not lose, but just right. Is this incorrect? if so then why?
I also failed (well didnt think i needed to) to fully prime the fuel lines. I read that air in the system could cause a runaway, but I would think after 3 screams through the power band it would've cleared it.
Airleaks. I've read all over that air leaks could be the issue, but how can I find a leak if it shoots straight to redline? As a kid I worked in a tire shop and we would use Spray9 for this purpose on slow leaking tires, but I don't have the time for it without risking damage to the motor (Fyi I did add oil to fuel for break in) but I didn't even have time to turn the water hose on. The motor has yet to run longer than maybe 10 seconds at a time without running away.
Thoughts?
btw I appreciate all the feedback. I never claimed to be a pro, and will certainly make a few goofball mistakes. If you see something say something, we are all here to learn and share and of course hand out the occasional dummy slap!
updated with cable pics.
