Not sure what this sludge is about. So far the pipe and gasket appear to be in good condition. No visible water marking or anything to indicate a sign of a leak. Im gonna fire up the compressor and blow the pipe out. See if i get any sand or debris. Stay tuned.
Well I cant get a good shot of the piston but i do see a milkshake coming down from the top of the jugs. Ill be pullin the head shortly. Guess the head gasket would make sense. All that pressure feeding into the ehxaust was the steam i was seeing from the pisser.That's not good at all. The 951 is known to get condensation but that looks like a lot more than that.
At this point I would suspect a head gasket.
Can you turn the engine over by hand and see if the top of the piston looks like it has been steam cleaned?
White motor the water flowed in opposite direction, not familiar with those details but it's different from silver 951. FWIW
Luckily when I originally assembled my 951 I read about people having head gasket issues so I bought 2. Already have it out there on the work bench waiting to be put back together. That got me thinking though would I see much benifit in buying a O ring head with domes and running 91 or 93? Also I owe you a big thanks for all the input and diagrams miki!Glad you solved the mystery. It’s not that uncommon on the 951. Make sure you use an OEM gasket and follow the manual to the letter including all the recommended sealants.
Can't be too careful, might wanna see a doctor about that smoking pisser.Make sure the cylinder drain tube isn't blocked as well.
Had to grab everyones attention somehowFirst thing I thought when I read that title was "penicillin".
I think the wrench is calibrated or atleast close there was just a small bit of pitting on the head and that lead to cataclysmic head gasket failure.@CreekerMike, I have to ask if your torque wrench is out of calibration. The last time I had an issue similar to this with a head gasket it was b/c I failed to torque the head properly.
I think a combination of heat, pressure, and brackish water accounted for that sort of blow out.I see, the gasket was eaten up surprisingly well. I thought the gasket was tougher than that.
Once they start going though the combustion gassed and steam just keep burning the hole bigger.
In my case I believe the small amount of pitting from the start allowed water in somewhere it shouldnt have been and that was the begining of the end for that gasket. In the case that theres a fresh head and deck to mate with then there shouldnt be any reason for the head gasket to fail aside from a huge amount of hours. But being that this is a 951 were talking about, there will probably be other large failures before those hours are achieved.Ya think? Really? Yes of course once a leak occurs they will get torched.
Often there's a reason though, like incorrect choice of gasket material/type.
Thats just a hunch though. I Only have one picture of the head I used before I ran it and due to the large amount of gasket material on it I cant very well tell how severe or not severe the pitting was.Ok, "pitting from the start". Got it.
