While riding our xp, it first lost power & wouldn't go faster than idle. If you added throttle it would die - but it would re-start & run at idle. Now it will not start & backfires thru carbs and sometimes thru exhaust.
I have:
replaced plugs
checked for water in gas
replaced fuel filter
put new fuel strait to carbs (with hose and funnel) to bypass fuel valve & hoses. It did not seem to draw any fuel from funnel while cranking.
Is there some sort of fuel pump or somthing to feed gas to the carbs?
Should I have the carbs rebuilt?
Any help would be great!
Thanks,
Scott
I have:
replaced plugs
Thanks,
Scott
