onefast66nova
I just got a 95 speedster that has been sitting for bout 8 years. Got all old gas out and going to clean the carbs out and check the lines. The strb engine fires and idles ok but does not rev too free but thinking that's due to junk in carbs. The port engine has no spark. I have not dug in too far and have downloaded the manual however I have some questions. I am good with 12 volt systems and this one is different than the cars I'm used to working on. In the manual it states that I need an ignition tester. Under test results there are no ohm values listed for the tests just the settings to use on the tester. I want to test all forms of the ign system and would like the values and not have to buy the tester. Any help would be great. Thanks in advance. Bill
