Alvright, this is gonna be along one...
Ordered new mpems from Dominic (very happy with service) installed mpems, started the engines and ran for a few seconds to make sure wiring was OK, both engines fired up. Went to the lake and decided to run the boat on the trailer in the water to test all the systems and make sure everything was 100% before going out... this is where the problems started with port engine, it ran for maybe 30 secs then died, realized fuel shut off was set to off, so I turned it on. When I went to fire the engine up all I got was a very short crank, so thinking it was bad solenoid I jumped it and engine rolled over but did not start, tried a few more things, got frustrated and just gave up. Took the boat home and left it for a couple days.
Finaly went back to it today and did some testing, if I unhook the ignition (black and red) wire going to mpem I get spark, and the engine fires right up when solenoid is jumped, if I connect the start solenoid connector from port engine and connect it to starbord engine it rolls over beautifully, and vice versa, it just doesnt like to turn the engine over in its proper location.
So the 2 issues I have are
-no spark when connected to mpem
- and short crank when connected to proper solenoid, I've replaced solenoid as well, and tried new engine ground.
Any input would be great
