Scottmoon92
Good morning all,
Let me get started by saying I have read 100s of post and have tried everything now I'm looking to the pros. About 3 months ago I purchased two 95 xps for a great deal and then the real fun had began. I took them out and they both ran like crap one only ran with about half choke and the other one wouldn't pick up unless I pulled the choke and let go real fast. So I started where everyone would and did a full rebuild on both carbs using mikuni parts however I did use a diffrent brand needle and seat. Both popoffs were set to 45 even though I cant find exacts on the pop off presure. Keep getting diffrent info from diffrent sites on what the actual popoff is supposed to be. For now I will just talk about one seadoo. The one where I would have to pull the choke and let go. I figured it was a popoff pressure issue so I took the carbs back off again and lowered the pop off pressure by putting in a diffrent spring and brought it down to 35 this helped the issue alot and she started running much better. After a short ride I noticed it wouldn't stay at full throttle it would bog down to about 5000 rpm and I limped it back. I let it sit for 20 min and tried again and it was good till I took hard corners and it went right back to the same issue. So I checked the voltage everything seemed normal wouldn't go over around 14.5 so I knew the voltage regulator was good. I took the carbs off again and made sure all was good which it was. I then decided to pull the fuel tank clean everything including the fuel selector and put everything back together. The ski ran much worse at this point it would rev up fast and hit a plain fast then bog down and almost die. So I bypassed the fuel switch and the fuel filter by plugging in the reserve directly to the carbs for a TEST it ran much better guess I'm getting air from there. It didn't want to pick up well but would go to full speed and hall ass again. However after 20 seconds at full speed it cuts back fast and acts like its overfueling pulling the choke makes things much worse and once I slow to a idle I can do it all over again. That's where it currently sits. This ski is running premix due to someone breaking off the oil pump cable that connects to the carb. I did do a janky fix to hold it on there but incase it breaks again I would rather run oil rich then lean so it's my temp fix. Unless that's what's causing my problems. Compression test at 130 and 135. I also replaced the upper exhaust gasket the one on top due to leaking water and cleaned the round donut copper one and put all back together. I did have a slight oil leak only when out of water coming from the PTO shaft but it has gone away since I have been testing. Sorry for making it long but I have been reading and reading and trying new things figured I would try and cover everything without having to reply a million times. Also forgive the punctuation I typed this out on my phone. Fyi the other ski is in the exact same boat lol
Thanks for your time,
Scott
Scott
