95 Sea Doo XP PWC RPM problem Need Help!!!
my xp ran at top end for about 15 min. then seemed to loose power, like running on one cylinder. run at idle for a few Min's. then will tack up to about 6000 then stumble back to idle. can slowly ease on the gas to about 4000 rpm and Cruz for about 5 min. Then it wants to stumble like running one one cylinder, till you let off the gas . Runs grate at idle, not running hot , has new plugs , pulled plugs, looked good . Cant figure out why the thing would run good at max with no misfire , now wont tack up and stay up. Need help please!
