I have a 95 GTX with the choke removed and a primer pump installed. It's a dual carb. The primer pump doesn't work well at all. It might take 20 pumps to get gas going in the line if at all. My Question, should this yr/model use a primer pump at all? Should I go back to the choke. It's a long run from the pump to the carb. Not sure why the pump doesn't work well but again, should this model be better suited with the choke?
