95 gtx not charging/replaced rectifier
treacy
95 gtx . Ski runs at 11.95 volts.
I have replaced the rectifier.
I have also cleaned all ground connectors/post in the electrical box, cleaned the ground terminal for the battery at the block,cleaned the 4 pin connector for the magneto.
What is the next possible avenue?
Can I test the Magneto with a mutimeter?
If so wich wires should I test?
I also not that the info/gauges do not come on.
Thanks for ant time
