95 GTX no spark
dtrwzb
I was riding and it quit, no spark now. Plugs not fouled. Checked resistance on stop/start switch, lanyard switch, ignition coil, and stator, all ohmed out ok. What voltage should be present at the primary side of the ignition coil? What else should I check?
unplug the blk/rd wire at coil (butt connector wire), then try to fire it up, if so, then you need mpem. I have a few, if need one.
I only had a few minutes to play with it today. I tried that, no change. I got one of the plug wire testers from the zone and tried it. The spark is there constantly, but very weak, the light is very dim and it will not fire the gap on a plug. Stator?
