IF you are doing new bearings it is a good idea to replace the shaft.
Yes, the shaft has a groove in it. You have to be really careful the thrust bearing doesn't get caught in the grove and crushed when putting the impeller on.
The easiest way to do it correctly is to put the new shaft in the vice then put everything over the stationary shaft and finally torque the impeller on.
