94 580 sp sea doo
david reed
if the fuel line check valve exiting at the left side of the hull is plugged what symptoms would i have runs for 5 min stalls then runs for less and less would this cause a vapor lock in the system i cant blow thru it the one at the handlebars i can is it safe to bypass for a test ride ihave replaced all fuel lines already checked fiters and bypassed reserve/off/gas on valve at wits end
