alright, sorry for the delay i was gone with family for the weekend, the blk/yellow wire has power, the red/yellow wire and terminal has 11.40volts and the other post has the same 11.40volts untill the start button is pushed which is normal, the blk/red wire to the mpem has 11.80volts, there is no blk/red wire that goes to the coil form the mpem
i did some testing on the 2 wires that go to the coil the white/black wire on the top had 0.13-0.14 volts when i tried to start it, and the black wire on the coil had the same0.13-0.14volts when the starter was engaged, then i tested the voltage from the mag, the white wire had 11.04 when cranking, i went over all the ground cleaned them up and took fine sandpaper to them, again i was testing for spark and attached the spark plug and grounded it on the head bolt and got a spark, it wasnt much but then i couldnt get another, it says in the shop manual if you dont attach the plug boots to the grounding tab by the flywheel and you try and start it that the coil of the mpem will get damaged, i did turn it over without attaching the boots to the tab, could that have blown up the coil or mpem
i just need to know what to check the voltage on next...
also Karl i think you made a mistake, in post #2 you said the red wire that goes to the vts is suppose to be attached on the starter terminal of the solenoid, and that can be right because it needs power all the time, and if it was attached to the starter side then it would only get power when you are trying to start the ski
