93 Sea Doo Fuel Sender Help
yamahaman101
I have rebuilt my carberators and still having the engine bog down issue when i pull full throddle. Does anyone know what the Ohm reading should be through the fuel sender leeds. I disconnected the wires from the circuit box and Ohmed them out with a reading of .97. I also tried to start the jet ski with my fluke leeds on the incoming wires and got a DC reading of 4.97. Does this seem right or is there an issue that might need some attention? I have also drained the gas, cleaned the fuel filter and blown out the fuel lines. Please help as I want to hit the water and cant do it. Thanks
needle and seat assy
when you rebuilt the carb/s, did you replace the "stock" n/s spring with one in the rebuild package?
Post in another location
I have a 2000 seadoo sportster boat and the gas gage, spedometer and rpm went dead, where are the fuses located.
Please direct your questions to the new thread section and not under a post that is containing someones issues that are not related. Thank you for your understanding.
