I just got this ski. It doesn't have the grey lines, but the PTO cylinder oil line is dissintegrating. I want to switch to premix.
The manual says to get to the oil pump you have to remove the carbs. To remove the carbs they say you unbolt the rotary valve cover with them to get out.
I can get only 3 screws out. The 4th which is the lower front one is too close and I can't get a wrench around it. It can't be as difficult as it seems.
How do you get the bolt off or what is the easier way to get the carb off?
(I already took the airbox and the flame arrester cover off)
Thanks.
Thanks.
