I have a weird one on my hands.
Working on a ski for a guy, needed a motor. Swapped in the new motor, went to start - nothing. So far I have 1) pulled the starter and tested it. Turns out it was grounding itself. Swapped in a new one. - nothing. 2) Swapped in a new solenoid, wasn't getting power across the solenoid. Swapped the solenoid AND the computer from a known good ski. Now getting power across the solenoid. - still won't crank. 3) Able to jump the solenoid directly and get the motor to crank now. When I try to start it will the lanyard on & button; the ski clicks and then nothing. Power getting sent across the solenoid, but no power getting to the starter. 4) Thought it could be a dead cell in the battery, swapped it for a known good one & same thing happens. 5) Cleaned up the terminals on both the battery and starter sides of the cables as well as the solenoid ends.
After all this, I still just get the dreadful click with nothing happening. Anyone have any ideas? Only thing I can think of is that the positive starter cable burnt up from the starter grounding itself.
Also - motor free as a bird, yes it spins by hand.
Any ideas would be appreciated as I have fought with this damn thing all day.
Thank you guys,
Jake
Thank you guys,
Jake
