Cal GTI
Understood about the carb cleaner, no lube for cylinders and drying affect with that stuff, but to get it jumped and create some heat .. Motoring the engine has near same effect though doesn't it, no lube oil in cylinders / fuel mixture during that cause fuel pump is not working.
Pulled PTO and cleaned pump housing, was full of fluid.
Question - trying to prime oil pump while I have carbs off and motoring engine. Why am I not getting any flow in tubes when I pull prime screw and move arm full flow? Does teh pump require vacuum when carbs are installed? Shouldn't I be able to prime oil pump with carbs off and moving oil pump arm full with bleed screw removed?
