95 seadoo speedster..
first time out boat ran ok, both engines showed water peeing from pee hole.
took boat to mechanic to have carbs on starboard side rebuilt.
took boat out and water wouldnt pee from peehole on starboard side
flushed engine from top at factory flush fitting, water come from peehole
installed t fitting at lower hose to flush jet and make sure water comes from peehole when pressure applied at lower iuntake hose
NO WATER COMES OUT PEE HOLE.
did find small small leak on exhaust pipe what looks like freeze plug,, used some jb weld to stop leak for testing tomorrow.
dont understand how water goes from tuned pipe into head where peehole line is located..
also would tiny tiny leak on tune pipe stop water from coming out pee hole and what is that freeze plug looking thing on the tune pipe,, there is 2 on each side of pipe.
