Hey guys, doing a bit of research into this. Looks like im not the only person who has had a spun main bearing in a 4 tec engine that has made a bit of mess with the case. So after a few phone calls to seadoo shops they said replace the cases. Called a few machine shops they said they might be able to weld, tunnel bore and repair the cases but how much am I willing to spend. So still thinking about options. They only need to skim a bit of metal from the cases and need bigger bearings to fit right..?
Well few people mentioned about using bmw bearings when you machine the crank down .5mm so got me thinking what size in the OD of the bearings? Is there some other engine out there that could be close?
Seadoo book has given us a crank measurement of 50.01mm max and 49.91mm min main journal size. So the search is on.
Found BMW bearings on “King bearings” they measure 49.97mm ID – 53.59mm OD and 17.6mm wide. If they are the ones they sell and that’s the bench mark I continued..
So “if” 53.59mm (I will have to measure this) is the main tunnel measurement and want to skim a bit what else is there..
Honda 49.97mm ID – 54mm OD – 19.96mm wide (Could trim these down) being 54mm OD would give .4mm material to remove. so BMW bearings are 17.6mm wide what else is close to that…
Mazda 49.93mm ID – 53.99mm OD – 17.5mm wide. (That’s close! And give .4mm to remove)
Ohh mercury marine use a bearing that’s 49.50mm ID (Would have to skim .5mm off crank and its 54.30mm OD (give you .7mm getting better)
There is lots of bearings
Well food for thought.. might have to go home and get the measuring stick out.
