I'm just getting started on trying to help a friend make his Sea Doo perform like I know it can. This is a newer four stroke, not sure of the model :ack: It is white, red, and black. Name is ??? 150 ??? I know, not much help, wish I knew more.
First things first, what rpm should the 4 strokes be running? his only reaches 5400rpm max. The tach goes to at least 8000 rpm so I know it's got to run higher, seems way too low. Plugs are brand new so I really can't check plug color.
Looks like the throttle opens all the way. He does have some kind of tank set-up on the back that fills with water so the thing can make a bigger wake for tubing. I checked that and it was empty(added weight).
Any key places to look.
I'd appreciate any help the forum can offer
