lilngineer
Hi Guys-
I am looking for some help with a stalling/bog problem I cant seem to solve on our 2000 Speedstee with the 240EFI.
Basically it goes like this. We launch the boat and get underway just fine with no issues. We drive the boat to a anchor spot and shut it down for a while.
After it has been sitting off for a while (I'll say a half hour or greater), I start the boat and it cranks a little longer but still fires right up. It will the either idle or stall. If it stalls, I start it and it fires right back up.
Now on to the real issue. Once it is idling steady, if I give it any gas below half throttle it sounds like it just bogs down and dies. I can restart again but will have the same issue. The only way I can clear it up and get underway isby quickly shifting into gear and throwing the throttle up past halfway momentarily and then it clears up.
Other than this consistent issue, the boat runs and drives great. It will come back down to idle with no stalling and performs great up to WOT.
Last summer I changed the port temp sensor, cleaned the fuel canister, reset the idles, calibrated the oil delivery and throttle position sensors. I also changed the plugs this year. I cannot get it to go away!
I am thinking it may be over oiling as it does seem to smoke a lot at idle. Or maybe a fuel pump? I am stumped! Please help!
