2019 Seadoo GTX stuck at 7200 RPMs
BruceXP116
Good afternoon, I’m having a problem with my 2019 seadoo GTX 230 and I’m wondering if you know what the problem could be. It is stuck at 7000 RPMs and 55 mph and won’t go higher, it’s supposed to go 8000-8200 and 65 mph. It has 60 hours on it. The prop has nothing in it and isn’t dinged up. It’s not cavitation because it accelerates fine, it will and can reach 8200 if I squeeze the throttle really fast while running it on water. Obviously, I’m not going to hold it there though. I’m out of options and I can’t find anything like it on the web. Thank you
spark plugs, supercharger clutch, wear ring out of tolerance, stator vanes, bad gas, injectors dirty, exhaust leak, oil overfilled, low compression, valves leaking, etc.
