2015 Sea Doo GTI 130 Issue Question?
sjl1009
Hey Guys,
I have a 2015 Sea Doo GTI 130 with only 50 hours. Yesterday I sucked up a tow rope but quickly realized and shut off the ski. I got under it on my lift, took off the intake grate, and removed the rope. Now that everything seems back to normal, my jet ski will not start? It was running perfectly until the rope. We have made sure there is gas, oil, etc. but ski will not start? Does anyone have any idea on what may be causing this?
Thank you so much.
Heck for spark as that is easy. Check fuses as they power the fuel pump and ignition. Give a spray of starting fluid into the intake while cranking.
One of these will solve or tell you where you need to be looking.
I would disconnect and then reconnect the battery to in effect reboot the software that runs the engine . A sudden unexpected stop unrelated to the normal shut down of the engine may have made the microcomputer run a muck .
