Hello everyone,
Need some help If anyone has some answers, 2012 RXP x ibr issue. Went to put ski in water ran it for a bit then ibr light came on along with engine light. Did my research on this site along with others. I can manual override ibr to move up or down in any position so I know it’s not the motor. I removed the ibr motor inside to check wiring, corrosion ect, along with the bucket in the stern Checked all bushings, rollers ect. There are a few rollers that should be replaced, which I will but don’t think that’s the issue. Fully knowing when I have the ski out of the water and can operate the ibr in override mode without any ibr light or engine light one, I know it’s not the motor or any of the bushings, loose bolts or worn or cracked rollers. Here’s the thing.... While on the hose and testing the ibr in N R & Forward, all is good but as soon as I jiggle or move the bucket in the stern, the ibr light & engine light comes on. I have no idea why this is. Can anyone chime in on your thoughts. Clearly when the ski is in the water and moving, this will move the bucket as I did with my hand and then the lights
Come on. The bucket doesn’t have any more play then my other 2012 RXT or my neighbors seadoos. They move exactly the same when you jiggle them with your hand. Just can’t figure this out. Battery, wires, fuses and everything else is perfect. Thanks in advance for your ideas guys.
Pete
Pete
