hiii98
took a while but i found the oil leak which appears to be coming from somewhere around or on the "oil pump housing". I took a video of the leak here
VID_20220904_142528.mp4
and
VID_20220904_140629.mp4
Now that I am fairly sure i found the leak, I am not sure how to proceed as I do not see any cracks or bad gaskets, but then again it is in a challenging spot, so i cant really see anyhow directly for inspection. I am not sure wha to do next. I found this breakdown of parts
2008 Sea-Doo 230 Wake 430 Oil Separator | Fox Powersports Sea-Doo Partshouse
Any advice would be greatly apprecaited, not sure how to take this apart or even if i need to or what my next step should be.... Boat has been running fine prior to this, i did adjust the throttles and likely caused this motor to rev way too high compared to the other motor due to not knowing what i was adjusting in throttle controls (this engine control was falling and not staying in position, loose and sloppy, i tightened it up with allen, but now its not in sync with other motor).
and
