2008 230 Wake fuse block replacement (part no. 204471091)
Benny jamin
Would anyone know where to locate one of these things? One of the injectors isn't working and apparently the fuse block is the issue.
When the mechanic changed over the fuse block from the other engine the engine was running fine, then changed it back and the issue comes back but theres no stock anywhere available that I can find.
Or what would be a solution to get the engine running properly again if this part cant be located ?
Cheers
Yea ... BRP isn't real good about supporting older watercraft. Ebay is your best bet, but some forum members also own repair shops, so somebody might have one.
