Re and Cheryl
No vst pressure?
Try swapping the 2 wires on the vst pump. Polarity matters.
When you had the vst apart, did you check that the float valve needle is free to move? They corrode closed from ethanol.
Polarity was correct and the float was free and working. After putting it back together I tested the fuel pressure right at the pump and got 45psi. Leak ckecking the rail and testing the pressure regulator today. If they both test good I’m assuming that the high pressure pump is intermittent, and will replace it and the low pressure pump just to be safe.
