keltonks
Your're right 'buddy. It's me again. I relish being at the top of the list. It invites more viewers to scan the thread that way. You guys are so off base it's ridiculous. You just can't accept that Sea Doo is imperfect. There was no abuse or neglect as far as my GTI was concerned. All fluids were topped off and adequate. The GTI was not ridden hard or at prolonged high rpms. Maybe you can make room in your closed minds that the problem is the procuct produced by SEA DOO!! Next you will be saying the space aliens who performed the anal probe on you zapped the timing chain with their laser beams. If I had abused, neglected or otherwise failed to maintain the machine I would never have contacted Sea Doo for reparations, started this thread or made the comments I have made. I don't care if you contact the mechanic that has the GTI, DZ Motorsports in Genoa Ohio (WHO IS NOT A DEALER!). Look them up on the Internet. DZ's tear-down of the GTI revealed that the GTI had not been abused or neglected. The mechanic could find no other problems with the engine, and no explanation for the timing chain failure other than a defective chain. No bolts have backed out and no other abnormalities are present that would lead to timing chain failure. If I had done anything to mistreat the GTI, or if I had neglected to perform some necesary maintenance, I would be man enough to admit it and keep my mouth shut. That's why I am so critical of Sea Doo. That's why I am trying to warn as many people as I can to beware when they purchase a Sea Doo product. Whether or not you believe me, I did nothing to cause the timing chain failure, either by an overt or covert action. The ultimate responsibility for the total engine failure was Sea Doo's manufacturing quality. The timing chain was defective or it would not have broken at this time in the GTI's hourly lifecycle. It's true it's a "freak" failure, which may only happen now and again, but it's also true that Sea Doo has denied responsibility, blaming, as do you, anything, everything and everybody else that can possibly be blamed.
And by the way it's not me that wears panties, it's that other die-hard Sea Doo devotee with the greasy wrench. My shorts are quite loose, thank you, as my waist is much narrower than my chest.
