2004 GTX Supercharged LEAKING COOLANT
Jetskichick
I have a 2004 Seadoo GTX 4tec limited supercharged and recently it indicated a hot engine and long beep. Got it to shore and the coolant reservoir was empty, hose from reservoir looked split so we replaced the hose and got more coolant, poured it in the reservoir and it disappeared. Didnt see it in the hull but we Turned it on and got an ENGINE OIL cue. The book said the cooling system capacity is 5.5L so we got another bottle and poured it in and it all flushed out and is now visible in the hull. Any ideas what the issue could be? Thanks in advance.
had similar symptoms couple summers ago,,,super best first move is to get an automotive type rad pressure tester,,,,pressurize the system to find the leak,,,in the end,,,I ended up tightening every coolant related clamp,,,and. mysteriously solved the leak.
