got a used 03 xp di this week.  took it out on the water yesterday for an hour and it was great... 360s, jumps, ran the throttle up etc...
took it out again today and it was great for the first 30 mins.. then it bogged down and cut out.. it continued to do that the rest of the day..
i can start it it up and it runs for a variable amount of time but never more than a few minutes and then it bogs again and cuts out... no RPM that it does this at really... if i try to start it back up immeditaely it starts but immed bogs out and cuts out. if i wait for 30-60 seconds i can start it up and give it a little gas but shortly it will bog out and cut.
I changed both plugs right there on the water but it didnt change anything. seems like the longer i let it sit the longer it will go before it bogs and cuts..
At one point the warning light came on during a few bog downs and read MAINT on the message area.
there is water shooting out the cooling bleed outlet...i assume this is normal..
NOTE: the sliding block assembly is broken and the part is on its way to me next week... not sure if this matters
any ideas as to what to check? there is 90 hours on the craft.
