While waiting for my OEM rectifier to arrive I cleaned up the battery to engine ground, battery to MPEM ground, and the rear electrical box to engine ground at the engine. (I did not follow this Engine to rear electrical box wire close enough to see where it attached in the rear electrical box in order to clean it). Also to possibly help with my other issue of my engine not reaching maximum rpm's I cleaned the rave valves. There was some carbon on both raves and the Seal that is pressed in to the pto rave housing looked like it might be compromised ( ordered two rave repair kits). So I installed the new OEM rectifier and rode the ski two different occasions for about one hour each with no maintenance light coming on-hallelujah! Thank you jhjesse for the firm recommendation of the OEM rectifier. Fyi-my original OEM rectifier, the cheapo eBay rectifier, and the heavy-duty OSD rectifier all checked out good when doing a diode test.
A fellow forum member discussed with me that there was no way to properly check these rectifiers.
As far as my rpm issue goes I was only reaching about 6500 rpm's but after cleaning the rave valves I actually lost about 200 rpm's and about 2 mph down to 38 mph. Later I found out that the brass tube that connects the airline to the rave housing popped out of the housing. (it looks like it was just a light press-fit)What do you think to refasten it-super glue, red Loctite, or some sort of epoxy?
Thanks for your help JIM.
