2002 GTX 951 Carb Engine Seized
A DIY option might be to drill a small Hole(s) in the Airbox at the proper location, install a Rubber Grommet(s) and plug it with a removable Nylon Plug(s).
A picture of where to put the hole would be cool. These dang 951's need lots of fogging. I've seen holes drilled on the intake air duct but wasn't sure the fog would get effectively that way.
The Di airboxes are only $22 on eBay with the fog fitting and nozzles. Too cheap to try and fudge something together.
Adding to the list of possible Options...
The best injection site is actually directly into the Accelerator Pump Carb Injector Ports or Tee-ing into the Accelerator Hose.
Seadoo Fogging Kit # 295500899 was made for this purpose.
"It consists of a "T", a One-way Valve, some Hose and Clamps. And instructions.
It T's into the accelerator pump hose and uses the accelerator pump nozzles to squirt seadoo lube down the carb throats. You will have a clear hose emerging from the carbs with a red squirter tube that you plug into your seadoo lube can. Iy makes fogging rediculously easy."
A Primer System could also serve the purpose, as mentioned before. Would need to pump Pre-Mix or Oil.
As far as the ideal location for the Air Box Fogging Port, you'll have to determine that.
That is cool, never seen that.
Do you know if they are still available? The part number only turns up and NOS one on eBay for $41.
eBay for sure. Maybe a Local Dealer has a NOS covered in dust on a back shelf. They'll have to search their Inventory at the Counter Computer.
But one could make there own with some Hose, Plastic Fittings and a small CHECK VALVE, if using with Accelerator Pump System.
If NO Accelerator Pump System, then it's basically a Primer Injection System that injects Fogging Oil or Premix.
I have an airbox that has a built in nipple on top towards rear. I wondered what it was for. It came off a 98 gtx.
