2001 SEADOO RX DI Drive Shaft Stripped
Knightri
Purchased 2001 RX Di Seadoo this year. In June the drive shaft broke. Some wear on the splines, but I would not say excessive for the year. Had drive shaft, pump and impeller replaced. Repair shop said they ran the ski and all was fine. However on my first outing the splines on the pump end stripped. Can anyone try to explain what would cause this? Repair shop owners said it was my holding throttle open when hitting waves. I have since had all the parts replaced by another shop and I have not had any trouble.
Welcome to the forum. If everything is assembled correctly, the splines shouldn't strip or slip. Are the rubber bumpers in both ends of the driveshaft? Everything else in place?
Try posting this in the 2-stroke PWC section of the forum. There should be more views there and maybe someone will have ideas for you.
