2001 Seadoo Di
SCOTTYH2O
I have a 2001 seadoo gtx di. and this year it seems like it is not getting on top of water like it should. it almost feels like it bogging down until you get on top of water and then it is smooth sailing. and i also notice it when coming out of a 360. Any help would be appreciated
Always check compression if you think you have a problem. That is a great starting point. That and new spark plugs.
Alright, thanks i will check compression. I did replace the plugs and still is doing it. but i will get back to you with the compression test. Thanks again!
I changed the fuel filter when i first noticed this issue about 2 months ago. what else should be done to the fuel system?
Ive read to get your injectors cleaned and check every offseason have to do all four at once and Thefuelinjectorman is the guy to go to.
