Before I even attempted to disassemble the VST, I did check the pressure at the VST and it showed 36 Psi !!!
And when I turn the key to "on", I can actually hear the pump. What a waste of time at that marina (time and money). But the thing is that after I left it with the Marina, the engine now would NOT start at all. If before it would start normally, but would stall after 4-5 minutes of running, now it wouldn't even start on idle. Starter is spinning, all sparks get voltage, but engine wouldn't start. Did try starting it on maximum throttle and only then the engine would start. Put the boat on the water and could run it on different speeds for couple of hours. It does smoke a bit, but I am hearing it is normal for 2 stroke. But my understanding is that all major components are working (fuel lines, electrical etc.). Am I correct in that statement? For example, if any of the 3 fuel pumps wouldn't work, I shouldn't be able to run the boat for 3 hours. Correct? Does it need tuning? Any other reasons for the engine not to start on idle, but on high throttle only? And, by the way, after running it for 5-10 minutes, I could start it on idle too.. Just not consistent. One time it would start on idle and next time wouldn't. Obviously something is still wrong.
