Doug212
Ok, I recently purchased 2 Seadoos. My 98 Gtx Limited is doing great. My 2000 RX is not so great. I started having a fuel problem and the RX was shutting down at WOT. So I replaced the grey fuel lines and cleaned the internal filters in the carbs. The RX ran perfect yesterday and I was hitting about 62 mph. Then today, my RX ran like brand new, I looked down and was doing 70+ mph not long after that i lost power and almost all compression in both cylinders. I took the exhaust off and removed the head and found the cylinders were etched and it looked like the rings were welded to the pistons on one side of the pistons. I don't know what caused this condition and I'm at a crossroad.
Should I buy a new 2 stroke 951 cylinder and top end kit or should I have the cylinders rehoned and put in a top end kit.
I have aftermarket intakes on the carbs and I read a post about water getting into the carbs when ski is running causing problems for the pistons and rings.
Any input would be appreciated!
