Hey Racerxxx, That fuelly motor has the stock crank, pistons, flywheel and cyl., but carb motor- stator, and housing. Is there any power or other issues I would have running it that way (it does run).. Rock
I can't answer for sure, but...... I know back in the day Ski-Doo would use the same crank BUT would alter the position of the woodruff key depending on if it was a points ignition or Bosch polar-fire ignition--depending on what year the sled was(going back to the sleds in the mid/late 70 into the 80's). Say a '75 340 with points had a different crank than a '79 340 with a Bosch Polar-fire ignition, the crank would fit but the key way was say 45 degrees different. So I'm not 100% sure on your situation, but I would assume if you stuffed all the carb mag and stator in the carbed mag housing and it runs you might be good to go.
I'm also assuming you have carbed jugs on the engine?
