yeah I have a tow rope man it will be all good.
My harbor fright compression gauge showed around 130 and when I bought a quality gauge, it was really over 140. Big difference! I threw out the harbor freight gauge.
Be careful tearing into a good running ski. I notice your a Fl rider so there could be salt use. If you break one bolt now you have opened up a big can of worms.
If your ski's compression is truly 120psi, it won't be running fine for long, you will need a rebuild.
Lou
With digital rpm and gps mph #'s we would know exactly where your ski is at. A thousand dollar rebuild bill is not worth the slightly better acceleration and 1-2 mph improvement that it would provide(assuming your compression is actually low). Unfortunately in the world we are living in down here it is only a thousand dollar ski in the first place.
you tried it with a another hf compression tester? i would try it with a good quality compression tester and see what it is. very possible u got 2 bad compression testers from hf. two tools that you should never cheap out on is a compression tester and a torque wrench.
however if u have a compression tester that is consistently 30 psi low thats a good tool to keep around when u go to buy skis. work the price down a bit.
I certainly hope that you meant your comment as a joke. How can we expect honesty from sellers when buyers are crooks?
Lou
