JeremyD615
Never take advice on oil from anyone that doesn’t specialize in Sea Doo. They’re almost always wrong...
You need a synthetic API-TC oil. Pull the hose off of the pump and let it gravity feed everything oout of the tank and lines. Clean everything out, and then open the bleed screw on the pump. Fill with oil and leave the bleed screw open until you get a solid stream of oil with no air. You can then close the bleed screw and let the motor prime the small lines from the pump to the manifold...
